Using E-gate MegaThread
twinbaby
hwsstx
ok, macsv2 has been registered. will it be a problem if I go in from JB custom but exit from Singapore airport?
I think it is ok...
You will not be Exiting at SG's airport, per your assumption but you will need to clear/Exit Immigration at Penang Airport & Enter SG...but take note at Penang airport not sure got E-Gate or not (but I think should have). Anyway better to ask the Officer before you Enter &/or Exit.
At JB you can ask the Officer about your plan trip & see what the Officer advice.
Please share here how it goes.
hwsstx
I think it is ok...
There are E-Gates at Penang Airport.
hwsstx
btw, is it ok, if I don't book a return flight to Singapore yet? I am undecided when to return maybe plus minus one day. 谢谢
Shouldn't be an issues, just ensure your submitted MDAC has taken care of the departure/exit date.
Blacky
Hi there, I am planning to take a flight from Senai Airport to save cost. Firstly, I need to go to JB first. If I go to JB, can I still use the MDAC registration, because I am having a multi leg trip and may end up back in Singapore instead of JB and back to Singapore again.
Here is what my itinerary will be like:
  1. Bus 970 ->
  2. JB Custom ->
  3. Bus to Senai Airport ->
  4. Kuala Lumpur via flight ->
  5. Penang via flight->
  6. Singapore
I want to use MDAC to avoid the queue, at the same time I am not sure if it is a good idea to have it not stamped because I go back to Singapore on my last leg.
Based on the info here
https://imigresen-online.imi.gov.my/mdac/main
It can be used only at the 2 land crossings at Johor and KLIA (both 1 & 2). You might have a problem if using MDAC to exit Penang n fly direct to SG. Can check with the officer or just get a stamp n this case.
Alternatively if you prefer to use MDAC, then fly domestic from Penang to KLIA, then back to SG
tqx
Can it be activated during weekends? Tomorrow I going , I already activate but my wife one not so she has to queue but not sure if weekend the custom can onboard her to mdac or not
deepblue_82
no at the moment only monday to thurs off peak timing...
Habrosus
Per instructions say only KL & JB but try if you have no other choice.
I could be wrong, but thought one of those posters or banners mentioned that MACS2.0 registration to be done at BSI (only?)...
And since now that they've designated only those counters between the 2 banners, not even 2nd Link, I doubt they'd entertain in Penang...
Even for KL, my understanding is that the use of eGates is allowed, not registration...?
tqx
Anyone face the issue that when go in can use gate but come out the gate show error?have to go counter to chop to go out. I faced this issue last sat
hwsstx
Most have encountered but most continue trying at different E-Gates till successful.
sacar101
Sorry if this has been answered previously. I have registered MDAC and able to use E gate on normal checkpoint. Can I use E gate on train checkpoint too?
lordfa9
hey folks, havent been around as much
Any latest updates that I need to update the OP with?
From what I know apparently they changed the regestration system so that if you are going in for the 1st time, you need to go to the specialized MACS counter Monday to Thursday 8am-7pm to enroll
hwsstx
Confusion between MDAC & MACSv02
