Water heater
infinity2014
currently in old hdb flat using joven 25L, when two toilets bathing at the same time, the water pressure drop. will AO smith 40L solve this issue? thanks.
djr81
Swee...
:s22:
Another AO Smith user :D
djr81
I dont think it will any different... i dont think there is a pump in the heater so its still depend on the water pressure from your main line... i might be wrong... y not just give AOS a call..
:s22:
kyteo79
40l vs 25 l ...
confirm 40l will outperform the 25l ... but confirm pressure will drop because 2 using shower from same source ...
sellun
Hi all, please help me list the pros and cons of the following two options
1) use AOS digital heater around $780
2) use normal water heater tank with smart switch around $600
Sent from Xiaomi MI MAX 2 using GAGT
kyteo79
You already said ... normal vs not normal ...
choice up to you ...
kyteo79
The newer model i think have smart control but not release yet...
:s22:
for me dun waste time educating or sharing if the party already have the heart to buy others ...
Only djr81 will be so kind ...
i awaiting the aos air purifier ..
MaoZeDuo
Few reasons I chose aos.
I wanna go digital but was unsure which smart switch to use for the heater.
Subsequently i have been using products from mi home and they do not have a switch that can cater for heaters.
The staff (Amanda i think) was also able to explain the product well which gave me confidence in this purchase. She was also very responsive with my enquires, even if they were not related to their products.
This type of product I feel local support is very important, even if its just for the digital panel.
Last but not least the thumbs up from the butties here :D
The only downside is i feel that my current household usage is not maximising the usage of the digital panel feature. But this purchase is definitely not a regret.
Hope this helps.
Gainduia
Hi All,
Would it be recommended to go for AOS Micro Heat Pump water heater or AOS Horizontal Digital water heater?
As SG is quite hot, wonder if it will be more energy saving? Or the heat pump water heater is much more expensive?
Have not went to showroom to understand more. Just want to gather some information first.
Thanks all!
kyteo79
Hope this helps.
good to hear you chose the old traditional method over the usuage of smart technlogies ...
Some things is better to use the old methods.
there is products elsewhere or even aos have such technology but is it worth the extra monies ? have the local market accepted this ? Will this new technology be stable ? will it be dangerous ? etc ...
Many things to consider ..
But 5 stars hotel/hospital choices is likely not wrong ... the direct distributor is strong and honest and tranparent. support is there and trainning always up to date.
Aos can be found in many high end stores and showrooms but the sales person unable to convince me to buy until i head down and had a chat with the boss ...
