Water heater
cscs3
I think better don't DIY and get a professional to install water heater coz there have been reports of people who got electrocuted and died because of water heater.
Water tank type or instant heater?
Just make sure main is off before working on it.
djr81
Me...
Anyone using AO Smith?
mirage_77
My instant water heater just died on me...
Any recommendations where I can get a cheap one + installation?
Only nid to last for one year+ cos house will be enbloc next year.
mun_hoe
to save on installation fees, advisable to buy back the same brand and possibly same successor model e.g same size, same mounting and DIY, remember the basics of 3 pin electrical wiring and switch off mains before working on it. hardly nothing can go wrong in a year
djr81
40l digital water heater.
3-4 Adults and 2 kids.
Water heater link to all toilet basin and kitchen.
Can just walk in to showroom see see look look..
U bought how many litres for how many pax in your household?
happydonkey
Wow 40l sufficient? I ordered 50l but still in time to change.
3 adults and 2 kids. Still pondering what size is better
Whitelion
I'm just wondering... is it more cost effective to keep the Storage heater ON or Turn it On as and when needed?
djr81
Enough.. not as if all my family member line ip and bath directly after 1 finish :s22:
All different timing bath mah..
:s22:
Prof. Utonium
Other than online any recommended shops to go to?
I would like to install water heater at my place for 2 toilets.
At the same time would like to install the bidet hose as the original were removed due to constant leaking when we first moved in ages back.
New mirrors too.
Lookong at a place where I would be able to get these done. If I order the items separately from online, I would need to get an electrician and a plumber by myself which may incur higher costs or not reliable.
Any opinions?
Twinky41
Hi, I just bought a resale unit and previous owner is using gas heater. I have got experience only with storage and instant heate.
Was wondering what’s the pros and cons of gas heater. Anyone with experience can help give me advice?
Syaman
Definitely the latter. You would not want your storage heater to constantly reheat the water inside it over the course of the day to maintain a certain temperature. Your electricity usage will definitely be higher.
Syaman
Gas water heater does not use electricity to heat up the water. In general, your gas bills will be lower compared to using a electricity to heat up water. It should be fine unless water pressure is not high enough to give you satisfactory rain shower - in which case a storage water heater is needed.
hotyrole
Hi,
New to this thread
My heater wall switch just same off haha
I was thinking if anyone got any digital wall switch to recommend to allow for timing usage and etc ?
happydonkey
Sian now. Cox the room on the lower floor (hdb em) cannot share the same hot water pipe. End up having to buy one more instant Heater. So actually 40l good for 4 🙄 guess not choice hopefully have more “stored” water to use. Zzz
Ok.. nice...
