Water heater
jefflowkh
Hi Ariston has replaces the tank. I got an external vendor to help and was replaced with $150 service fee. They gave me a new tank yeah.
jtec14
Hi all,
I am thinking to keep gas supply for cooking only and removing the citygas water heater left by the previous owner, is it possible?
For the water heater, is it only citygas personnel can remove, including sealing up the part of gas pipe?
Thank you.
daveteo88
Call citygas to remove the gas pipe cost 70
Go down to SP will cost 30 and they do it for u
Go down to SP?
Remove the heater and go down to SP?
If ownself know how to remove safely, still remove it and go to SP??? For what??????
daveteo88
I decided to go with the 30L Ariston to save some cash and see how it goes. This is my first time using a Water Heater tank so need to level up some experience. Been using Instant heater all my life, time to change lifestyle lol.
Gas or electrical cheaper?
mitch92
Hi all, I have a Joven SA10 Instant water heater which does not heat up a single bit unless I turn the knob to full maximum power. The knob has level 1 to 8, but 1 to 7 all damn cold like never on but only 8 is very warm like what it is supposed to be. The heater going to gone case le arh? I thought Joven like pretty reliable one but both my Joven SA10 in both toilets having their own problems now.
aleehl
I have a joven jh25, the round cylinder horizontal one. We have been noticing a burning plastic / metal smell when we switch on the heater. Everything else still works fine, externally all seems normal. Anyone face the same issue?
peqasus
Can this be done?
HI jus wondering if this can be done. anyone did something similar?
sellun
Make sure your smart plug can provide 15A current which I don't think normal smart plug is capable of. If not it will burn
Sent from HUAWEI EVR-L29 using GAGT
sellun
Not all, the model he quoted max power is 3000watt. Divide by 240volt current only 12.5A. so 15A should be more than enough.
bumsteroid
Smart Wifi Glass wall switch 20A for water heater / AC
Water heater need at lease 20A power rating socket/plug.
Bought smart Wifi wall switch to replace water heater old switch
20A. Install the App Ewelink. Features auto timer and Auto Schedule and notification when on/off. Cheap cost @ $21. but Require Neutral wire. Tap from power socket. now Any normal water heater can suddenly become smart water heater.;)
NiHaoma123
Hi there,
Any one facing issues that every 6am in the morning, my storage heater will have a high pitched noise and its super loud? My heater from Europace and they exchanged a new set for me out of goodwill but after installing the new set, the sounds still persist.
Abit headache and tired now cos this has been ongoing for damn long and HDB BSC and my plumbers are constantly pushing the blame to each other.
cscs3
Is not calculate this way. Usually you need 50% allowance. 12.5A+50% is approximately 20A.
cscs3
This is not smart, this is just automated.
Smart means your water heater know your usage pattern and on/off accordingly.
bumsteroid
smart water shower device
@csc3
any recommendation on smart water shower device?
Prefer gadget that can be self-DIY install without plumber
Basic Feature to report water usage & temperature ideally can extend function with opensource or IFTTT ?
Found in Amazon this Amphiro A1/ Pani Smart Water Monitor
which appear to be popular :s13:
sorry i dun hv enough post count to include the amz links but can google it.
anyone using these or similar water reporting devices
kindly comment on their pros & cons. thks! 🤔
micgoh
im wondering does the tank saves more money when comes to electric bill? I been using tank and now change to instant. felt its easier to maintain and also lowering of electric bill. but those tanks I had was from like last 10years. so tech may have advance and save electric.
however didnt have experience with current tanks. maybe someone can share
jeffrey745
Any brand recommendations for gd quality water tank heater?
My hse using joven water heater tank for past 3-4yrs and 1 day it suddenly stopped working. Whenever we turn on the water heater the whole house electricity will trip....
Any instant water heater to recommend? And place to purchase? Just need something cheap for office.
Was looking at champs wish & champs city
I also need installation! TIA!!
