Why no more point block hdb?
  • Need help?
    Reach out to someone from Samaritans of Singapore (24 hours): Call 1-767 or WhatsApp 9151-1767 More info
samloi
stayed in point blk before.
used to tower over the whole area and have great views until the newer development came about.
Gets windy at night with the wooo wooow wooo sound. 2 lifts available and every once in a blue moon both will spoil and then you see everyone sitting around cause too high to climb.
When yang that time kept thinking what if i kick the wall during sleep and the wall fall over.....will jitao drop all the way down cause next door is nothing liao
And yes, its a hot bed for suicides. during the peak of the 98 crisis, the 2 point point blks in the neighbourhood take turns alternate mths
Dracky
Not just HDB, there are no new point blocks for condos either.
gungho
The design is simple
Central core is lift shaft, and stairwell, which acts as harden shelter per scdf guidelines.
Then the sky is the limit, at the top roof is connected with adjacent building creating elevated space at the very top
jeffprobst
Sorry hor. Our precious are all reserved for private developer for building private properties and commercial, especially those good location and near mrt.
trevlim
those 5-rm HDB point blocks are huge in size and usually include a large exterior balcony. The units are usually spread out around the central lift lobby. such a good design.
pushtopen
question, last time also use prefab floors and units like nowadays?
or they built it? or use custom fabs/molds?
iirc, for point blocks last time HDB also offer the home owners the chance to buy part of the corridor for certain corner units due to layout/design quirks right?
campoix
hdbs are getting smaller. Why daydream about HDB building bigger apartments?
yoongf
Old pt blk... 1 set of lifts serve 4 units per floor.
Newer design serve min 8 units per floor
the_dog
why no more point block ?
answer is...
daniel_83
BTO also got point block
my BTO 12 years ago consist of 2 x 4room point blocks
1 floor only 4 units, like a typical point block
gungho
On a long term horizon, isn’t pt blk more efficient
for a 99 leasehold
to demolish and rebuild
