kelvinti
- Jan 5, 2009
Anyway to turn this off?
I observe that notifications from Instagram are always delayed..
Go to Battery & performance > Choose apps >
**Note: If your IG's notification is still delayed after turning the Battery saver off. You might have to put your IG app in Autostart if you have not done so.
Delayed notifications can be cause by either Battery Saver is turned On or the app is not in the Autostart or both.
So, it should be no problem with Mi Max running Global 9.5.2.0 too!
