Krabs.
- May 8, 2007
the black color battery , all are imitation , there is no "real" or "authentic" battery , their temperature data will stay @ 29 d celcius forever , nohon one the temperature data will go up/downThanks for the heads up krabs. That’s really helpful. I’m gonna order it. The bottom half of the screen is now lifted by itself due to the bloated battery but i’m afraid to lift it up completely in case I break anything. Noob question, how do we know the battery is genuine?
when buying the nohon battery from that biggest seller with 300+ reviews , can add on 1cent USB cable 1.5m , search the store "list all product" and filter by cheapest
I haven't change yet , will do it tomorrow when sunlight is better
this phone it drop on the staircase and the casing can never close back since , battery too bloated
if you start from zero , then follow the image guide on the product webpage and search youtube to see how the fingerprint sensor unlatch and how much effort u need to pull out the adhesive under the old battery
use something to pry open the corner until it lift up like 1-2 mm and you insert the plastic piece to "unlatch" all 4 side of the rectangle in clockwise or anti-clockside continuous , like those old candybar style phone from 10 years ago , there are about 10+ latches on all 4 side
https://www.youtube.com/watch?v=q14cVrEAIZU
some part of this video can be skipped as we don't disassemble until screen
don't use the sucker cup to keep on lifting the screen , some people broke their screen this way and they mentioned it on their battery review
