Joelleyuan
- Sep 24, 2005
good to hear!Mine don't notice any difference
i read abt battery drain in the hyperos thread and it's other phone models.
Definitely will hike, since XM starting to rebrand to higher end segment of mobile device market. More or less, POCO will be affected to a certain extent. Lets hope it still delivers the required to justify the pricing.I think f6 will have a price hike as well... Lets see...
Don't see a need to upgrade as of now
Oh yeah i completely forgot about it. Malaysia also can. Last time i change to Egypt for my F2 Pro hahaFor those whom want to upgrade to HyperOS for poco f5
Under settings > additional settings > region
Change it to Hong Kong. OTA will flow in
Else is continue to wait for OTA to reach SG.![]()
Hahaha to me is just a rename for miui.... But didnt notice any diff as of now other than some new lockscreens.Updated to HyperOS on Poco F5. Haven't played around much with it but nothing much LOL. Battery certainly didn't drain though.
Yes battery is fine. Didnt notice much difference from A13
To me, its the exact same OS. Settings menu design, overall OS design exactly the same... Maybe just to create hype ba... But for me didn't notice much change....The Settings page still messy, still bloaty so i dunno what's the need to change the name so drastically. Makes people less excited about them doing the same next time.
As a standalone phone, HyperOS is pretty much just a renamed and more optimised MIUI. But if you are in China where Xiaomi ecosystem is much more extensive, there should be some noticeable difference. It was redesigned to integrate better with their IOT anyway.The Settings page still messy, still bloaty so i dunno what's the need to change the name so drastically. Makes people less excited about them doing the same next time.
Believe more for the entire XM's ecosystem rather than significant singular change to MIUI.Updated to HyperOS on Poco F5. Haven't played around much with it but nothing much LOL. Battery certainly didn't drain though.
Most of the consumer would not care if it it linux or vela, end of the day unless you are into their ecosystem, its just another "rename" MIUI. As long as it is more efficient, most user will not mind.Xiaomi HyperOS uses both Linux and Vela kernels. Vela is Xiaomi's IoT platform based on NuttX RTOS.
Reference:
https://www.gizmochina.com/2023/10/23/xiaomi-hyperos-architecture-officially-revealed/
https://en.wikipedia.org/wiki/NuttX
Other minor differences: for example, they claim HyperOS occupies less space than MIUI.
https://www.mi.com/global/hyperos
What is the version of Android for this hyperOS? 13 or 14?As a standalone phone, HyperOS is pretty much just a renamed and more optimised MIUI. But if you are in China where Xiaomi ecosystem is much more extensive, there should be some noticeable difference. It was redesigned to integrate better with their IOT anyway.
Android 14What is the version of Android for this hyperOS? 13 or 14?
Won't the x or m series be better option and cheaper too. F series is the higher end of poco.At what price point is f5 a good deal?
Think I missed the f4 at 200+ boat liao.
Or any other alternative?
Buying for elderly mom but basic use.
So entry level is enough. Or lower mid tier.
Thanks
Thanks
I read very scary reviews on the m3 thread.Won't the x or m series be better option and cheaper too. F series is the higher end of poco.
Imo if can get below $300 is good deal. Maybe $250-280 kind as it won't get any lower based on F4 sales.
hmm, maybe wait after F6 is launched, then hope F5 to reduce price to $200+I read very scary reviews on the m3 thread.
X seems viable
But if 200+ can get f4, why pay the same for x?
Likely the x can be cheaper during sale.I read very scary reviews on the m3 thread.
X seems viable
