Jun Jun
Mlo shows one band and works like smart connect now atm so it is broken. And it does not work with easy mesh atm. All these will be fixed. I have highlighted all your concerns and mine to them.
mr_won
There's some video / photo buffering issues in YouTube and FB / IG when using BE805.
There's also sometimes when the WiFi connection remains but no internet access.
I am not sure if it's the router firmware issue or M1 routing issue because connecting to a VPN somehow "solves" the buffering issue -> The videos loads very quickly. Any ideas how this can be solved or is it likely a M1 backend issue?
Jun Jun
Yes i have feedback all ur issues. Faced.
Jun Jun
As i m also experiencing the same issues.
Jun Jun
Dont think is m1. As after turning off and on the wifi it became ok. Modem did not restart
Jun Jun
Currently also on the beta firmware that i m using it seems to be better.
Fronsac
I think recently they onboarded too many users so congestion exists, it only happen this few weeks, youtube will get stuck or buffer but mostly go away after a while. Fully wired and router is a UDM SE so unlikely to be internal network issue.
skazzz
The support was telling me their website have been this issue since Feb, i have tried to recontract for 5 times and 5 times after you enter your cc details at the end, it said not to refresh or close window then it disappear and blank page. Checked with support and they said my order didnt went through.
Tried chrome, chrome private mode, clear cache, MS edge etc all dont work lol. so done with it
bad business still dont want to even allow recontract to take place properly
i also tried mobile, intermittent went through
really trying your luck on their online store despite trying to pay them
any idea what was the known promo for 10gbps?
Only for selected recontract user, S$50.90 per month for M1 10Gbps plan, with free two Asus ZenWiFi BT10 (usually price at S$63.90 per month).
the promotion is over. You might need to wait awhile. It was previously $34.90 for new users and $32.90 for *selected re-contracting users
For existing users, the recontract offer may still be there for targetted users.
There is a report that M1 Physical Shop may still have new home offer (S$34.90 per month for M1 6Gbps plan) and new user ISP switching offer (S$35.90 per month for M1 6Gbps plan), with free TP-Link Archer BE805.
https://forums.hardwarezone.com.sg/...comparison-latest-promo-deals.6665380/page-87
Just an update : M1 walk-in change ISP still allows $35.90/mth 6gb plan with free BE805 router. Hope that helps those who missed.
YMMV
