so far the 1.2.2 build is OK. Didnt observe any dropping of SSIDHi , whats the situation with your BE805 so far?
I have another beta 1.2.2so far the 1.2.2 build is OK. Didnt observe any dropping of SSID
Yes i have feedback all ur issues. Faced.There's some video / photo buffering issues in YouTube and FB / IG when using BE805.
There's also sometimes when the WiFi connection remains but no internet access.
I am not sure if it's the router firmware issue or M1 routing issue because connecting to a VPN somehow "solves" the buffering issue -> The videos loads very quickly. Any ideas how this can be solved or is it likely a M1 backend issue?
As i m also experiencing the same issues.There's some video / photo buffering issues in YouTube and FB / IG when using BE805.
Dont think is m1. As after turning off and on the wifi it became ok. Modem did not restartThere's some video / photo buffering issues in YouTube and FB / IG when using BE805.
Currently also on the beta firmware that i m using it seems to be better.There's some video / photo buffering issues in YouTube and FB / IG when using BE805.
I think recently they onboarded too many users so congestion exists, it only happen this few weeks, youtube will get stuck or buffer but mostly go away after a while. Fully wired and router is a UDM SE so unlikely to be internal network issue.There's some video / photo buffering issues in YouTube and FB / IG when using BE805.
the promotion is over. You might need to wait awhile. It was previously $34.90 for new users and $32.90 for *selected re-contracting users6Gbps is $44.90 per month now?
Was looking to sign this plan.
Ok thanksthe promotion is over. You might need to wait awhile. It was previously $34.90 for new users and $32.90 for *selected re-contracting users
The support was telling me their website have been this issue since Feb, i have tried to recontract for 5 times and 5 times after you enter your cc details at the end, it said not to refresh or close window then it disappear and blank page. Checked with support and they said my order didnt went through.
Tried chrome, chrome private mode, clear cache, MS edge etc all dont work lol. so done with it
any idea what was the known promo for 10gbps?
Just an update : M1 walk-in change ISP still allows $35.90/mth 6gb plan with free BE805 router. Hope that helps those who missed.
YMMV
