May 2015 SBF
tiarasimplicity
Thank you for your application to buy a 4-room flat Tampines. Unfortunately, as your balloted queue position has far exceeded the flat supply, we regret to inform that your application has not been successful.
Now my qns is:
1. Its rejected because I apply at tamp or because we are not married and we applied for sobf or its not within 2km with our parents? I'm staying at pasir ris and him at simei. My fiancé is first timer and we applied for scheme MCPS.
2. What is the next step we should take: sobf for tamp again or sobf at other location or bto tamp? We don't really like bto because the wait is way too long of 3-4 yrs.
Can any kind soul explain this to me? And would appreciate for any advices. Thank you :)
I am very curious why our application is unsuccesful.
Gixxerfied
Now my qns is:
1) Becos luck was not on your side. the rest of the point u pointed out is not valid.
2) That is up to you
Doesnt mean u use MCPS will definitely get a good no or even a valid no.
Doesnt mean u're not married then chances lower
Tampines 4rm has only 13 available unit with a grand total of 328 applicants with 17.6 first timer applicants for every available unit for 1st timer.
For mature estate break down, 95% is allocated for 1st timer meaning about 12 units with a total of about 211 application for it.
tiarasimplicity
Thanks for the explanation. Mind advise me for my case, what is the best or save step for me to take next? Sept sobf in tamp again? Sept bto in tamp? I really want the sobf but I'm not sure will it be another waste of time or there are still chances to apply for sobf tamp again?
Gixxerfied
Sept got no BTO for Tamp, only 2 sites which is Punggol & Bidadari..So it really depends on you and your bf..
Sobf u must see the number of unit if available for Tampines..Tampines usually one of the hot spot so definitely more applicants..More applicant lowers your chances of a guarantee no..But still if Tampines is place which is convenient to both of you then go for it, it boils down to luck..
tiarasimplicity
Oh no wonder... okay maybe the best I need to apply for bto if I want tamp. For sobf maybe bedok or punggol.
thesal
What I did was look at the first timer applicant rate of each estate on the last few days and chose the one with the highest possible chance.
end up choosing Punggol and got a ballot number that guarantees a unit.
By the way, the application rate at mature estate is significantly higher than those of new estates (Punggol etc)
Gixxerfied
Wont know if Tampines has any near future launches..You have to wait for Sept BTO launch to find out the sites for the next launch..
tiarasimplicity
This really explains all. Appreciate your assistance. Meaning to say that, if we apply punggol we cannot use MCPS. Do u think there will be high chances also if i apply sobf at punggol?
Gixxerfied
How to use MCPS when the criteria is within 2km radius of parents??
End up it would depend on the number of available units and total number of applicants..
thesal
You need to see the applicant rate and units available. What I do know is that this cycle got quite a lot of Pungool apartments for SOBF compared to Nov 14 (340 vs 118 for 4rm).
Can check here for reference.
http://www.hdb.gov.sg/fi10/fi10321p.nsf/w/BuyingNewFlatYourAppl?OpenDocument
Anyway, its unlikely that you can use MCPS for Tampines... 2km is much shorter than you think.
Mandy_dy
Hi all, have anyone of u success get a queue number but not eligible to buy new flat?
Need advise from u all.
Thank you. ☺
lwch_1990
Emo nemo ... Anyone know can I apply for Sept BTO con-currently even though I have applied already for the below woodland SOBF?
Thank you for your application to buy a 4-room flat at Woodlands.
2 Your application has been balloted with a queue position of 223. Although your queue position is beyond the 195 unit(s) of flats on offer, some of the applicant(s) ahead of you may not book a flat. Thus, there is a chance that you may be able to book a flat on your selection appointment.
Alfs1709
From what I understand from other forums U can. But once the result for sept BTO is released, you will lose your queue number for this round of SOBF.
