[CASE] Phanteks Enthoo EVOLV ATX
evq
guys, where r ur pic? GPGT leh lol
Now that my case is on my desk, i find it noisy.:(
JasK
I've got cut a few times handling 2014 Jonsbo cases. They were not even "legal" when it comes to international standard. Until today, I'm very very cautious when handling Jonsbo even though the edges are rounded of. You don't know when you may be sliced up :s13:
OT, the Jonsbo UMX4+ is also very nice what. Dual window, two piece aluminium exterior. Same price as the Evolv ATX though!
How much is this UMX4+ and where in SLS can I get it?
SECTORTWO
Here's my rig...still haven't wrapped the case yet and some cables are messy because I'm too lazy to remove the motherboard to access those cable management holes (along the bottom edge of it).
My thoughts about building in this case:
+ Really stunning to look at.
+ Cable management holes are pretty well placed but the bottom ones could be a bit bigger to make it easier to squeeze cables through.
+ Not too noisy.
- Build quality could be a little better. Some parts are slightly bent that I had to bend back. Screw holes tend to not match up because some pieces of metal prefer to "twist" in a certain way - had to forcefully shift it back to use the screw holes.
- Small spot on my front USB door that isn't anodised black (either that or it was scratched during production).
- Cable management space in the rear is a little tight if you are using extensions like me. Can't get the door to close nicely on mine.
~ Some corners are pretty damn sharp...please be careful when building.
evq
Nice!
Btw, u can place the Hue+ between the psu & side window panel.
How is the Hue+? I intend to get one
kira86
just changed to luxe few days back .
in short loving this , so much room compared to my define R2 , but much more noisy la
SECTORTWO
Nice!
Yup...I tried placing it there but I didn't like the look of it at that spot.
The Hue+ is pretty neat, the magnets make it easy to place and adjust and the lighting is pretty even.
evq
Oh just suggestion, why don't u swap ur optic drive with ur hue+, so that u can just swing open ur side panel a bit to access it.
SECTORTWO
Actually I planned to do that at first but the Hue+ is a bit thick to fit under the 2nd graphics card. Also the front area is slightly shallower than the back part so a bit harder to fit the optical drive (the drive is also a little too wide and one corner of it will end up sitting on the PCIe rubber grommet). Plus the optical drive is slot load and it "spits" the disc quite far out...the door has to be open quite wide to access it anyway. :(
