Water heater
justintch11
any comment on Rinnai instant water heater?
I initially thought of getting Rinnai too. But now I will be getting Panasonic DH-3NDP1MS (With DC Pump) or DH-3MP2MS (Without DC Pump). Cheaper by at least $100+ but must buy from JB. Panasonic design is nice in my opinion. Cheers.
yyylll
initially i wanted to get Panasonic from msia , but worry about the warranty. m'sia has more Panasonic models as compared with SG.
justintch11
Same thoughts initially but warranty covers the same standard 1 year and 5 years DC pump. Except warranty in JB. I don't think instant water heater will have much issues anyway. Going in next week to check out more about warranty with shop and all good I will buy. If interested, drop me a PM and I will inform you. :s22:
djr81
Go to their showroom look for amanda..
Nice showroom, product knowledge good, special price for BTO and most inportant is good fast neat and ontime installation.
Hey, I'm quite interested AOS digital heater. Would you mind PM me who is the salesperson to look for?
alex22
MYR $315
PANASONIC DH3NS1 (White)
Lazada Msia.
Less than 2KG in retail packaging...
Carry back from JB on foot, easy peasy.
DH3NS1 English manual -
https://www.scribd.com/document/382855397/Dh3ns1-2-Dh3np2-Inst-Eng
andylow4421
Looking at AO Smith Tank Digital Water Heater, not sure how many liters are sufficient. Whether 40L enough?
- BTO
- Only for 2 bathrooms
- Cater for 4 persons
- Individual shower about 5-10 mins
Please let me know if you have kangtao for this order + installation. Thanks!
djr81
Im using 40liters for 2 toilets and kitchen.
More then enough for me. 3 adults 2 kids.
- BTO
funky05
im thinking of getting the instant water heater with rainshower.. deciding between champs legend and rubine.. any feedback?
theblueark
You might want to rethink the instant water heater + rain shower combo. Instant water heaters are pressure reducing systems. The heater needs to reduce the flow rate so that it has enough time to heat up the water as it comes out. The hotter you want the water, the lower the pressure.
Rain showers usually have a lot of big holes and need a lot of pressure. You combine low pressure with big rain shower head, might end up with just a drizzle or just a water trickling out of some of the holes, not rain.
funky05
thanks bro... not advisable even with pump? cos champs and rubine comes with the booster pump..
andylow4421
Just saw the post exactly the one I am looking at! I will look for Amanda. Pls help me to confirm the address:
178 Paya Lebar Road, #05-10
Singapore 409030
Thank you =)! I am go for 40L then
theblueark
vintagelink
I bought the rubine instant heater with rain shower in 2016 when my unit was going through the HIP. Honestly, the turbo feature was turned off by me after it gives out a strange loud vibration. Quite disappointing but could be just my luck. Just sharing my experience with you.
funky05
Thanks bro.. was contemplating rubine and champs
funky05
I see, my mistake I didn’t google those 2. If they come with the pump and rain shower as a set then I guess they should be designed for that purpose properly already.
Quick google lands me on this thread, maybe the feedback there can help you a bit: https://forums.hardwarezone.com.sg/...ater-heater-rwh-2388-rain-shower-5425505.html
Been reading all till I got confused lol.. But salesman told me no issues with pressure except it's noisy.. But I have fair share of people recommending both the brands which further confuses me lol
dunkmycar
Anyone using a gas heater?
I just bought a resale unit with a Rinnai gas heater and realised the water is hot-cold-hot-cold even though the tap is on the red side and not switched off. This is the same across both bathrooms. Anyone encountered a similar issue before?
kyteo79
Singapore 409030
40l got digital ...
the rest no.. so 40l is good choice.
kyteo79
Same as mine when i bought my resale ..
Immediately when storage heater AOS
kyteo79
Simply trust the salesman then get it ...
trust the members here then listen advise here.
We dun gain a single cent.
dunkmycar
Oh no so you switched to storage heater instead? Did you have to call citygas to cut off the supply to the showers? Rinnai quoted me $1750+ for a replacement including labour costs! That's crazy
