- Sep 16, 2018
what firmware are you all on? i don't see the option to bridge
1. Did you log in the super-admin account?
User name --> support
Password --> reverse of the root password printed on the ONR.
Hardware Version V2.1
Software Version V2.1.10P5N19
Boot Version V2.1.10P10N5
2. ONR bridging method
Bridging method has not been changed from the very beginning.
Log in the super-admin account:
Once you log in, click "FastSetting" on the top right to access the briging page.
Set your router in router mode and connect to LAN5 (10G LAN port) and make sure you have internet access in this case (Double NAT).
Click the checkbox LAN5 to bridge the 10G LAN port.
If you lose internet access immediately, bridging failed. Reboot your router to see if it helps. If not, bridging confirm failed. Uncheck the "LAN5" checkbox to recover.
If you still get internet access, most likely your bridging is working. Double check your router WAN side gets public IPv4 address and not private IPv4 address (192.168.1.x). You may need to reboot the router to get the public IPv4 address. If that is the case, congratualtions, bridging is successful.
If bridging is successful, then you cannot access ONR's GUI 192.168.1.254 any more from your own router connect to the bridged LAN port. But you can connect your computer to the unbridged ONR LAN port to access the ONR Web UI at 192.168.1.254. The ONR itself actually still has internet access but somehow your computer cannot access the internet when connected to the unbridged LAN port.
3. ONR Bridging behaviour
1) Initially it was very easy to bridge, and the unbridged ports will still have Internet Access
2) Then with new FW, bridging became not working in August 2024, you would lose internet imediately.
3) Then it became possible again for some users, the unbridged ports will not have internet access. Some users still can not bridge the ONR. No idea why the differences, even with the same ONR HW/FW revision.
