- Sep 16, 2018
Nice. Thanks for the report and confirmation that IPv6 is available from SIMBA 10Gbps plan.
Need to get report from those using 2.5Gbps plan as well to confirm that they have IPv6 as well.
Does that mean there's still CGNAT issue?Nice. Thanks for the report and confirmation that IPv6 is available from SIMBA 10Gbps plan.
Refer to this chart on pg 94 by XiaofanAny lags with games ? Planning to switch after contract ends in Oct
After my appointment with NLT is completed on 6 Aug where the technician found out one of the fiber cable is broken/damaged. He is kind enough to help me repaired it. On 7 Aug, Simba confirmed that Netlink has activated my FTP. I didn't opt for installation service since everything is plug n play. I just removed the previous ISP router and replaced it with the new Simba router. The rest of the set up remains unchanged. I'm using Google nest wifi as the main router and a 1st generation Google wifi as a secondary mesh router.I just signed up their 10GBps plan and am from North East
Tested the speed, achieved less than 500mbps using wifi.
I am still on M1 500mbps aldy more than 7yrs so far so gd.If you have doubts, better play safe and stay with M1. I would venture to say new M1 2.5Gbps plan is much better than SIMBA 10Gbps for your use cases.
TP-Link Tapo should still work as it uses TP-Link web services (no matter you pay for Tapo Care or not).
https://www.tapo.com/sg//tapocare/
No idea about Dahua CCTV, If you need to carry out port forwarding now, then it will not work under SIMBA CGNAT.
As for your Asus ZenWiFi XD5, that will still work but you may need to upgrade to a 10G capable router to fully utlize the bandwidth. ZenWiFi XD5 is a low end mesh solution from Asus which is only good for 1Gbps plans.
I for sure don't have the necessary hardwares to enjoy the high speed internet. I'm not complaining since my usage is just emails, web browsing and YouTube videos. I don't play online games.That is actually normal WiFi speed with Google Nest or Google WiFi which is only capable of 1G wired and less using wireless.
You may want to carry out the test using wired connection. USB 3 to 2.5G adapter is not expensive if you do not have 2.5G capable devices.
It is more expensive to test 10G if you do not have existing 10G capable devices.
I presume your WAN is set to DHCPv6?
Yes.I presume your WAN is set to DHCPv6?
Also, you're on the 2.5Gbps plan or 10Gbps plan?
Dahua DVR/NVR using P2P can work as normal . no need to do port forwardingIf you have doubts, better play safe and stay with M1. I would venture to say new M1 2.5Gbps plan is much better than SIMBA 10Gbps for your use cases.
Simba is the same as M1 I think it only provide ONT and u have to connect your own wireless router to the ONT.one quick question, what routers compatible with simba 10gbps? tks
i have a ont appointment tmr and is it after the ont thingy i can start using the simba ?
my previous router is from m1 tho , if i am not wrong is asus router
https://en.ocworkbench.com/simba-10...es-8-173-gbps-downlink-and-7-686-gbps-uplink/
Says here that IPV6 is not offered on 2.5
